I got some deep dish bullitts this week and wanna know what tire pressure your guys are running. TIA
damn thats kinda high aint it... i bet it spins like hell when you get on it... i have always ran 35 in every thing of minei run about 48 pounds...max on the sumitomos i have is 51...anything under 45 on my car the tires look flat and ride like ****
for some reason when there is any less pressure than that i can push on the tires and they will flex...but with that pressure before the supercharger they wouldnt spin at all even with full bolt ons...but they'll still catch alright in second with the blowerdamn thats kinda high aint it... i bet it spins like hell when you get on it... i have always ran 35 in every thing of mine
If you push on one spot ur creating a good amount of pressure in that one small area under ur finger. the amount of tire on the ground would be much larger and require less are to be stiff. You will likely benefit from a decrease on pressure.for some reason when there is any less pressure than that i can push on the tires and they will flex...but with that pressure before the supercharger they wouldnt spin at all even with full bolt ons...but they'll still catch alright in second with the blower
Mustangworld - Moving the wiper arms downWhat about 275-40-18.. and 365-35-18
And does anyone know how to do the free mod for the wiper blades. (lowering them?)
I read about it but I dont know what to do to make them lower after I take them off...
You are gonna wear your tires VERY badly at 48psi. What size are they? REar your owners manual or door sticker and see what they should be ran at! When you over inflate tires the center of the tread will wear and when you under inflate them (anything below 32) the center with actually LIFT and NOT have much contact the ground with radial tires and the outside of the tread will wear. If you want proper information you need to go to a tire specialist and ask.
