1 - 20 of 26 Posts
I finished taking out all of my stereo equipment and pulled the rear and passenger seats. I had to leave the backs on the rear cause the track mandates no open holes in fire wall or trunk area to the cabin.
I ran some 12.8's in the quarter on motor before my dyno tune. Got a set of 555R's on the back now. I plan on running a few motor passes and see what it does before spraying it.
Any info on where I should be as far as 1/8th mile times would be appreciated.
i think 7 is fast as ****, 8 is quick, 9 is decent
it depends on your goals and what you want to hit. i know some say there is an equation that adds up 1/8th to 1/4 times. but who knows how close they are. i would just shoot for mid to high 6's and call it a day.
If you hook good on the 555R's and have skinny front you should be in the high 7's on motor, i would probably be right at a 8 flat with front runners on the 17" 555R's i ran on and you have almost 100 more WHP than me on motor vs motor so if you drive it right i say high 7's on motor, around a 7.2-7.4 on the spray if you ream it good
Resident Diabetic...
Isn't low 7's cobra territory? I can see that in all honesty if you have a low 60' time.
Where are you running the 1/8? Kennedale?
Are you running those times in your sig on motor or juice? I have some stock cobra wheels on the car. 555's on the front and 555R's 275's in the back. I have not even done a real burn out on them yet cause they are two weeks old and I didn't want to waste them unless at the track. The line lock is going to get a work out tomorrow.
I will have my wife take videos for me too.
Put a real tire on the car. Nitto's are never going to get you where you want to be.
Discussion Starter #9 (Edited)
Clarksville,TN. I think it is called Clarksville raceway. It is like 10 minutes from me and I don't have time right now to go to Bowlingreen, which I am super excited about only being an hour away from here.
If low 7's is stock cobra territory, then I am not far off on motor. If it is a pullied cobra then the sauce should put me in there.
After this new insight I think I will for sure make a pass on motor and maybe even let out of it the first run just to see were I sit. I would hate to run too fast the first time and not get to enjoy myself.
Discussion Starter #10
These are going to have to do for now. My 15's are in my house hold goods shipment and I don't have them.
If I can rip off 1.7s I would be happy with these tires.
well with your power i would think high 11's/very bottom 12's aren't out of the question on motor. my best pass in my '95 was an 11.8 and in the 1/8 mile it was a 7.62. so i would say anything from a 7.6-7.9 in the 1/8 on motor would be good. then 7.2 and under on spray.
I understand:D Those Nittos are going to be frustrating to say the least. Lots of heat in them and a good clutch slip is what's needed.
Yeah on bald 17" 555R's with the stock 18"s up front on motor
Ran a better 60 foot on street tires N/A than i did on nitrous with DR's lol, it just spun all of 1st n a little of 2nd on the spray n DR's.
Discussion Starter #15
Thanks for the tipon these tires. I will do my best.
I plan on setting my window switch to lock out first and spray second on.
low sevens is more like pullied cobra territory. that would be quite a bit ahead of a stock cobra. stock cobra is more like 8.0-8.1 with a good driver
Discussion Starter #17
Good to know. I guess I will just let it rip the first pass on motor and see what times it spits out.
you should post a vid of your runs. im about 2 weeks out before i go to the track. sucks i have to wait but i work nights and the track is open friday during the days.
Discussion Starter #19
I will. I have a iPhone 4 and a regular Camra I am going to let her use to video. Hopefully she can get some good videos with one of them. I will post them tomorrow in-between runs.
since your on street tires i will forgive you if you spin your ass off and run some slow times when it comes to spraying your car down.
1 - 20 of 26 Posts
