1 - 20 of 23 Posts
when yall put your cai and tune packages on? i mean how much harder do these stangs pull? i am anticipating a lot from what i heard with a racer 95mm and sct2 from brenspeed. anyone messed with sniper tuning software? i'm asking because i can finally afford to invest in my car. i want a no bullshit package that will help me pull low times. so, i'm probably going with the following: c&l 95mm w/ sct2 or sniper, 4.10's/eaton lsd, bmr cnc lca/upper 3rd, o/rx, upd, charge plate deletes. about $1800 drop right there. but i'm hoping to get in the 12's. 12.99 doesnt matter... i have a grudge with a chevy feind. had my car dyno'd at creedle's... 1994 mustang dyno, loaded run it pull a peak 257.7 and 274.8.. worst after three and lots of heat soak 249.6 and 267.0... couldnt get a wideband on it because he melted a lead.
i want 300+ hp 300+tq. 390+ on gas.
sorry no scanner or i'd give you the printout. next time i go i'll email the file to my computer. before and after i install cai/tune, charge deletes, udp's, midpipe.
should be interesting.
so as soon as i get this "economic stickler bribe to stay in america and not move to canada check..", i'll do all the above. good? no good?
n2o
with intake, tune, x pipe, udp's, and delete plates you should be above of what you want.
i just dont waste money on all the hipe.
save the money on the bolt on ****, and go straight for the blower if you want real results
  • Like
Reactions: 8t6gt
+1... i started with all of the bolt on stuff and wish i would have just went with a blower... cuz it took me almost a year to get to a 13.0-high 12 whereas i could have boght a blower and been almost at 11s now..
yea, thats what i WANT... what i need is cheap 12's
125 shot of nitrous is cheap 12's
damn skippy! i wish i had a 100lb n2o tank. i want this thing to do it on its own power.
11's on gas..
so you want a 12 sec N/a mustang right? thats a pretty simple goal for the S197. with the bolt-on mods you want an average driver can hit 12's with no problem.
i always wanted a 12 sec car and when i bought the mustang i realized that was pretty easy, so im looking for low-mid 11's.
Discussion Starter · #13 ·
thanks bunz. i appreciate it. make it seam easy
Discussion Starter · #16 ·
will do. amazing these really are bolt on cars. they might go down as some of the easiest to make fast.
yeah these 3v's are great cars! to think, i use to be an import guy and never liked mustangs. i was so naive back then, even though they're some great imports.
my thoughts are your going to spend prety close, but not quoite as much on all those bolt ons as you would on a blower setup, but youll go a lot faster and enjoy your car a lot more with the blower. just a thought, and just putting those options out there for ya
1 - 20 of 23 Posts
