1 - 10 of 10 Posts
Retired MM Ninjas
I have an '04 Mach 1 with virtually all of the bolt on's. The only thing that I haven't installed is a MAF or an intake spacer, and I haven't ported my intake. While I am saving for a forged lower end, cams and a blower. I just want to take care of all of the cheaper more minute things that may help for future mods. Once again thank you guys for all of the help.
Have you considered an intake spacer? Aluminum DS?
MM's Orangest
The MAF you can do without until you get the blower. The spacer is a very cheap ($100) 10lbs of torque. There aren't any HP gains that are noticeable but that torque is nice. Long tubes and an aluminum D/S are other options you have too.
Retired MM Ninjas
Thank's I have already eyed up an aluminum ds, what about the porting? worthwhile or waste of time?
MM's Orangest
I'll let you know in a week.
Retired MM Ninjas
Please do, who is going to do your porting? Are you having Paul's do the porting? Also are cars are pretty close in setup, would it be accurate to suggest that my car makes around the same amount of power? I haven't had mine dynoed yet though. Also I am going to buy the intake spacer for sure.
I doubt that your car will make the exact amount of HP as his.
MM's Orangest
I'm actually having Sweet2kstang do it. I'll let you know how it turns out.
1 - 10 of 10 Posts
