1 - 8 of 8 Posts
i have a stock 302 block with trick flow 185 heads. i have a supercharger thats got about 5 lbs of boost.i have b303 now but i want something a little better. i know probly you will all say custom cam but i was just wondering what is good blower cam example e303,tfs stage 2
i want a good street setup
If your ganna get a crappy ots grin like ford go f303 cam. There are tons of good anderson grinds, but I have no experience with them. If you are on 5 psi it's way less time consuming to go 8 rib on the crank and blower pulley and get a smaller pulley for 10psi.
i have get the anderson b-451 cam or b-51 cam i run the b-451 with afr 185's a systemax and a 347 on 10.5 psi maybe 11psi i make 616.9 rwhp and 576 rwtq cam builds great top end and falls off about 6,400 rpms lopes reli good and is streetable
1 - 8 of 8 Posts
