So my car makes a very repetitive *pop* when making a very tight right/left hand turn (like busting a U). If I go grandma slow, crawling, it doesn't happen. If I drive normal (very lightly still), it happens every time. It happens 100% of the time in one spot, as I'm turning nearly full lock to the right (not all the way) and the pavement dips, then rises (one street meeting another). Other places is a gamble,,but this one spot it always happens. Very annoying.
It's at least 4-5 good *pops*
balljoints? (I'm very familiar with balljoint problems,,but this sound is like a metal marble bouncing on metal,,,if that makes sense.). I'm used to a balljoints just making ONE *pop*,,this sounds like a loose sway bar......(read below)
something in the steering?
Car feels tight on the hwy. Tracks straight,,,no drifting,,very responsive. No pops or other bad sounds at any other time.
What's going on? '02gt 5spd (doesn't matter if I'm in gear or not)
----OH YA,,,I noticed the sway bar hanger,,the part that connects the front sway bar to car (there's two of them),,under the hood, bottom of the car,,one of the metal arms appeared to be cracked open on the driver's side. Was just barely split open,,and the other side did not have this split (it looked so clean I could see it being factory/normal). Is the sway bar 'sway'n' over to one side,,and that hanger/mount that's split is making a pop sound? (all the bushings look good) With car on a lift I grabbed the front tires, and there's was absolutley ZERO play in the tires.
help me out,,,i need to make this problem go bye bye!
