1 - 11 of 11 Posts
Ok so when I slam into second gear i get wheel hope REALLY bad.I need to know how would I eliminate it,heres my suspension mods..
18inch Fr500's, tires are bridgestone 255-40-18F's
rears are Eagle F1 runflats (stock on the corvette) 275-40-18
KYB 5 way adjustable up front on stiffest setting with MM CC plates
Rear are 8 way adjustable the setting rite now is on 4 and I also have
BBK springs, fronts are 1.8ish drop rear are 1.5 drop
I have a 2004 Mustang Gt rearend (wider then 94-98) and everything else is stock...WOuld i need some upper and lower control arms to eliminate wheel hop and what brand should I go with? Wheel hop is when the upper control arm is being used more then the lowers?
Thats what I thought I just needed to clarify that thanx for the quick response
I'm guessing lca's and some sub frame connectors would completely cure your problem.
I gonna have to say that it's more likely just the LCA's, I have subframe connectors(welded in) and still have horrible wheel hop.
Anyone have real proof of which type to go with between poly bushing or sherical. I know the spherical ones tend to be noisey on the street, but do the poly ones actually solve the wheel hop?
maximum motorsports and team z make quality suspension parts. A little pricey but when it comes to suspension its worth the extra dollar
Resident Headbanger
get some lower control arms, you will have no wheel hop after the install.
Depends on which ones you get. I have the Maximum Motorsports LCAs with 3-piece urethane bushings on the chassis end and spherical bearings on the axle end. No wheelhop whatsoever and that's with the quad shocks removed as well.
I just did the Maxium Motorsports LCA's. I wld go for them they cost the extra penny but they are very well built! I haven't had a chance to get out and try them out yet since it won't stop raining here!
1 - 11 of 11 Posts
