I know I said this before but I now feel this is doable and I just need some detailed assurance this is all I need.Ok I decided I am going to build my own kit from parts all over the place to build one sofar Ive come up with the following for me?
Sct Tuner
T70 Turbo $200
boost controller $10
Turbo cooling and inlet pipes $100
42lb injectors $369
SVT Cobra pump $190
Intercooler $100
oil feed drain lines $20
BOV $60
wastegate $60
would this be all I need to pursue this or would I also need a bigger MAF sensor and upgrade fuel rails or is the stock ones fine
Total in parts $1100 and people that im gonna try to get to help me for $150 a piece
:shiftyeyes:no
theres a lot wrong with that list.
THE BIGGEST being a T70 Turbo for $200....if you even get an EBAY turbo for that little it has 2week limit writen all over it.
either way a T70 is much to big for a stock motor none the less with stock h/c/i
you want like a 54trim or 57trim...(t57)
My personal opinion. I ran a SC44 Garret Precision and it spooled very quick with 278rwhp to as much as 440rwhp
its going to cost much more then $200 for that turbo though....although i sold my SC44 for $100 but that was to a friend
second thing is this looks mostly like every part and price was picked off ebbay...which most people do so its common...but most parts are bad...
the only thing i know that works good off ebay is a 44mm Wastegate...i have to buddys with 700hp 2jz's that use that wastegate with no issue.
the BOV go Tial...best BOV you're going to buy.
My personal recommendation is Tial wastegate and BOV...you're going to spend money but it'll be done correctly...thats the only way to do a turbo setup...they're a headache at times as it is why go with parts that'll be half-a$$.
for $1000-1500 you're not going to piece a turbo kit together thats going to work well. period, theres no middle line or ground to it.
the intercooler...is a no as well. $100 intercooler is crap. I should have taken the pic of an SRT4 one night. ebay $100-150 intercooler the welds completely blew out where it meets the intercooler core. not just 1 spot...from top to bottom. sure maybe you wont have as much boost or that problem but why use an intercooler thats rated for 300hp and will be just as good as just a straight pipe probably
idk where you're getting a boost controller for $10 but i wouldnt buy it....
THE ONLY cheap style boost controller that works believe it or not is Home Depot. same 700hp 2jz's run home depot boost controllers:yes works for 22psi....i dont like recommending it just because people think that the rest of the kit can be like that...
those 2jz's run Precision intercoolers and $1,000 turbos with everything done correctly.
next thing...a GT40 pump is much better then a cobra pump and cheaper
another huge thing missed...exhaust and hot side piping...the custom stuff.. that isnt cheap. and has to be custom done. theres no way around it.
last but not least. theres NO CHEAP WAY TO DO A TURBO system...before i paid the $4000 for my turbo kit and setup i thought just like you....the quicker that gets out of your head the better off you'll be.
