1 - 13 of 13 Posts
well the smog pump you can just pull and use a smaller belt, as for the ac id use the PS relocation kit, brings ps pump to where ac pump is almost its $50, if you jsut google ac delete kit youll find it
to add to his question... I already have an o/r h-pipe so my cats wont clog, but what ports will i need to block off and can i just take the egr spacer off, or is there more of an importance to it more than emissions? Thanks!!!
well there is a ports in the back of your heads that a bolt will screw into to block off. But if your state is strict on emissions then I would keep it with what they say. My state is strict but I have friends in the inspections business so I have a loop hole to slip by
my state (Michigan) doesnt seem strict at all. So is this the only port with vacuum that I should be worried about or are there more on the EGR spacer?
well the port on the back of the heads arent vacuums. Exhaust comes out of the back of the head. I am not sure about the EGR spacer I dont have one on mine b/c I am running a BBK SSI intake and the intake comes with a place t omount the EGR
I have the ps relocation kit and it's pretty sweet, I also have the smog pump eliminator which I bought from summit I can't remember the brand again worked perfectly. As far as the egr I run a block off plate and alot of people will say that you will have problems after eliminating it which is b.s. I have had no issues, it will throw a egr code.
I have had NO PROBLEM out of not running a EGR:cool:
yeah thats what I was saying but if you check your codes you should have a code pop up for egr. Unless you have one of those eliminators plugged into the harness.
1 - 13 of 13 Posts
