When installing the ford racing oil pump can you reuse the stock pickup instead of the one supplied? I’m not dropping the pan, or wasn’t planning on it anyways and not sure if I’m going to have the room to reach in and install the pickup that came with the oil pump. Also doesn’t look like it comes with a gasket or o ring that goes in between the pump and the pickup, those that have installed aftermarket pumps did you have to order that separately from the parts store or did yours come with the gasket or o ring (not sure which one is used, I assume a gasket)
