I need engine lift brackets for an 03 SVT motor. I am sure they are the same as the regular 4.6L, but just in case, i wanted to clarify. So, does anybody know where i can purchase these brackets.
Thanks
Thanks
If you access to a lift thats the way to go!ive always found the easiest way to pull my motor (4v) is to just drop it out the bottom:2cents
If thats the case I could see how disassembling the engine could be a waste.I wont be pullin mine out the whole way (jus droppin the K to do LT's) but im glad to see that those alternator tabs are strong enough to hold![]()
they mount onto the front side of the heads to be able to allow you to tilt the engine up and out. They are rather expensive though if you were to get them from ford but im sure you can fab something up to work. If you need pictures on how they look just let me know and I can do a quick scan for you. Also have you tried over on SVTperformance to see if anyone has any or call up Steve @ Tousley Ford Parts Depot and see if he has them as he does 10% above cost on everything.I have seen brackets in pictures that look like they attach somewhere around the cylinder heads. They are long and bent. I have found some for 350.00, but would rather fab some up before spending that much on brackets that will only be used once or twice.
Putting a 4.6 into a 67 mustang isnt too big of an obstacle. i just thoughtI could save some time if the brackets were readily available for a reasonable price. BTW, i have started a thread in the classic forum if anybody would like to follow it.
Thanks
http://www.moddedmustangs.com/forum...7-fastback-4-6l-svt-project-follow-along.html
Im usin a bar with chains across the strut towers to hold it up while I pull the k member to put in LT's...should work out pretty good lolIf thats the case I could see how disassembling the engine could be a waste.
BTW I didn't mean that to be a smartass commentYou're putting an 281 ci supercharged fuel injected modular motor into a '67 fastback and you're biggest problem is lifting the engine? Wow...
I can't wait to get home so I can see the pictures of this thing!Putting a 4.6 into a 67 mustang isnt too big of an obstacle.
