1 - 20 of 28 Posts
hey guys im looking into buying a new/remanufactured engine in the next few months and figured id start doing my research now. what is a good place to buy from for an affordable price? also being im going to take out the 3.8 i have in my 96 now i think im going to upgrade my motor. any suggestions? i was thinking along the lines of the 4.6 or the 5.0 but the question is which one? any ideas suggestions or comments are appreciated! thanks!
Rich
Discussion Starter · #2 ·
also, should i just buy the block and everything else individually that way i can build it to my desire of course or would it be better to just buy the engine as a whole. i think i would be looking into some big cash if i were to build the engine myself right?
MM's Resident Ricer
if your gonna go through with a v8 swap 351 is about all thats worth it
MM's Resident Ricer
a 94-95 gt kmember and mounts, and all the 5.0 wireing harness and such. It will fit the windsor is a direct replacement for the 5.0
MM's Resident Ricer
no biut it wouldnt work with a 5.0 either you wi'll need a new bell housing
MM's official Chevy guy
when u say buy all the parts and build it to ur diser do u mean buy all the parts then have some one do it for u or do it ur self, because if it is ur self, do u have the knoledge and skills to do it, of not i would not seggest going that rought
im doing a lil reading up on the windsor motor and its saying that if i were to take cleveland heads and throw them on the windsor block that would pretty much create the boss 302. would that be the way to go or no?
Discussion Starter · #11 ·
ive never actually built an engine from the block up. however i have done that head gasket and heads on my current v6 on my own.
MM's Resident Ricer
yeah you just need the bellhousing, and Cleavland heads in a windsor are a popular swap but it is real pricey clevland stuff is a lot more expensive
i would say that a stage 2 cluch should hold fine
u may want to ask in the 5.0 section on wear a good place to get a 351 is,
also head and head haskets are farly easy justa time consuming and paing in the ass process.
were engin build ing us a lot harder becasue there r a lor more things u need to be carful with and do just right.
but im not gana say u can't or shouldent do it, because i don't know ur actual macanical abilatys, however i would say it would be wize to rething this and make the right decision.
Discussion Starter · #16 ·
kool kool , i gotchya. i fouind this website here Ford 8 Cylinder Engines where i can get a 351w motor that fits a 94-96 lightning for 1800 bucks. would that work or no? and also are there certain years i should steer clear of due to like recalls and **** or what not?
if it is carbed it will have a carb siting on top of it, or an tintake for a carb, u wont see a place for a tb
MM's Resident Ricer
1800 is good google ford crate motors there are a lot of sites and a lot of different hp ratings a lot of places sell turn key engines where you drop it in and go
1 - 20 of 28 Posts
