1 - 8 of 8 Posts
i'm looking at buying a vortech supercharger kit. but the biggest kit that i can find for my car only makes 10 psi. im looking for something in the 15 psi range. so does anyone know where i can get a pulley that would overdrive the supercharger to that range?
you can buy them from lethalperformance, vortech or what ever company you bought it from, or summit racing.
if you run your car at 15psi on a stock block that is going to cause some trouble.
US Air Force (retired)
If you want to run 15 psi then you should get a mid-size supercharger such as a D1-SC and order it with a smaller pulley. There's nothing in your garage so we don't know what type of motor you have, but, as FloridaStang mentioned, if you put it on a stock motor your motor isn't going to last very long. It might not even make it off the dyno.
Hope you're not planning on running 15psi on the stock motor. Which supercharger did you get? You can get pulleys on ebay as well.
i have a 4.6l 2v. im planning on puttin eagle competition internals in it with +17cc pistons, a crower stage 2 cams that is designed for supercharger applications, 44cc trick flow heads, thicker copper head gaskets, and a trick flow intake. as for the trans i plan on buying a PA aode transmission and TCI 2400 stall converter.
1 - 8 of 8 Posts
