1 - 20 of 35 Posts
Just Cheesin'
Just Cheesin'
Do you know how we'll it fits? I may do the autozone one as a temp setup.
Yeah I would do the steering column one. I have the dash pod with my Boost/Vav and wideband in there. But Im going to buy an oil pressure gauge, keep the boost/vac and oil in the dash pod, and put the wideband in the steering column one.
I like the column mounts. I've seen a couple in person, and they fit pretty good. I mounted mine where my stock head unit was an aftermarket unit to the place where my stock CD player was. I made the pod out of ABS for about $15. I've still got room for two more in the future. With you're car being a double din, that's probably not an option for you unless you swap it out. I think go with the column mount.
I've had this in the car for about 3 months and still haven't hooked it up...
I <3 Boost
here ya go OP. AutoMeter 96-04 Mustang Steering Column Gauge Pod
man get that thing hooked up! took me about 20min.
Just Cheesin'
Discussion Starter #10
I have a double din though. I think I'll do the AZ one for temp then eventually get the pod. Really right not I need function more than form. I just need the gauge in plain sight. I was even thinking of just zip tying it to the column for a few days.
Just Cheesin'
Discussion Starter #11
I can get the pod from AZ for for 29. I get a discount.
I've still got weld in the bung, lol.
EDIT: I'm with JoshC. The autometer is the one I'm referring to as far as fitting well. They're about the same cost, why not spend the money on a nice piece the first time?
youve got a tuner, right? turn off the rear O2's and pull one out then toss in the gauges O2 sensor :yes
My rears are already off, but I thought the wideband had to be in front of the cats? I have a full exhaust with L/T's, but I went with a catted H for inspection reasons. If not, then I'll do this tomorrow after work!
I <3 Boost
ah yeah... thought you didnt have cats....
You guy's have motivated me to get it done though. I want to go out and hook it up this weekend now!
Still slow.
Ive seen someone on this form put it in the vent in the center above your stereo. Can't even tell its there till its on.
1 - 20 of 35 Posts
