1 - 20 of 39 Posts
Coming up close 100,000 miles and wanna know which clutch to go with... Best price and quality...any references?
Well...where do I find it? Cause my summit catalog shows just the like pre 01's...and what else will I need to replace?
Sweet, would you recommend that for me too? I need to replace mine very soon...
what count is my input spline? cause i see 10 ans 26 as options
mm's nitrous mod
Discussion Starter · #14 ·
Any thing else I should buy when buying that kit? I don't see the throwout bearing in the kit...and I was thinking of muying the steeda quadrant kit that comes with the quadrant the cable and firewall adjuster
mm's nitrous mod
an adjustable set up is recommended when car is going to be abused. surface flywheel or replaceif needed, TOB if not in kit, and you should be set.
Discussion Starter · #16 ·
Hopefully my flywheel is fine it doesnt chatter or anything so it should be good just resurface it ....
Discussion Starter · #18 ·
If its not good where ever I take it to be resurfaced should tell me right? And the tranny takes 3.2 quarts right?
Discussion Starter · #19 ·
I almost forgot...what about my pilot bearing? Just give it some grease?
mm's nitrous mod
the machinist that you take it to will know if it can be surfaced or not. visually check the pilot, and grease or replace if needed.
1 - 20 of 39 Posts
