1 - 20 of 23 Posts
I am finishing my wiring and I have came a cross some loose ends... This is not the original harness, my car was a 4CYL 1988 LX and the harness is out of a 5.0 L 1989 LX.
1. (A) These are located on the driver side by the coil and strut tower.
1. (B) Colors of wires.
2. (A) This is located in the same area.
2. (B) Side shot of plug.
3. (A) This is located on the passenger side by the fuel rail.
3. (B) Side shot of plug.
ANY HELP WOULD BE AWESOME...:cool::cool::cool: Thanks guys - Joe
Sheriff Metal Face
I think the square one in the first pic is for your coolant level sensor that is supposed to be attached to your overflow cap. But it doesn't look like you have a cap with a sensor.
I don't think that plug in the second pic goes to anything. I remember my friend's 86 had two plugs like that by the coil. One connected to a wire that went to the solenoid I think and the other just layed there.
The first one goes inside the fenderwell and its for the washer fluid reservoir motor.
#1=washer fluid reservoir
#2, not sure but looks like the horn plug but i cant quite remember.
i might be wrong, but I thought the sensor in the last 2 pics plugged into the small black wire that comes off of the negative cable on the starter solenoid. im not positive though. best of luck...im in the same boat as you right now, its frustrating i know.
looks like a bunch of bs that doesnt matter if you saw how many plugs and wires i ripped out of my car you would **** bricks..
e3sean im in the same boat as you....so much unused crap, i just left it all in there though its just unplugged.
1 - 20 of 23 Posts
