1 - 11 of 11 Posts
I am currently running 275/40/17 nittos. I would like to find a drag radial in a 275/50/17 who makes that size? I want to go with a taller tire to knock a few rpm's off at the top of the 1/4. thanks John
nobodyy makes a 275/50/17 DR but MT does make a 295/45/17 DR which is 28" tall.
with 4.10's you do need a 28" tall tire.
whats your trap speed, and in what gear, and RPM?
Discussion Starter · #4 · (Edited)
I have not run it since the vortech install, but last time I did run it spraying it I like 6000 going through the traps. I woud like to shave a few rpms off. my car is an auto by the way
will the 295 fit on a stock 01 gt rim ?
actually with the bigger sidewall it may fit ok.
jsut curious though, why not just buy a set of prostars for the rear soem 15X8's with 6.5" backspacing, and then a set of 28X11.5" slicks. that would be your best bet.
MT DR's wear VERY quickly.
thats a good idea I might just go that route. thanks for your help
4.10s would raise your rpms going thru the finish, unless it gets you to the next gear that much quicker
1 - 11 of 11 Posts
