1 - 20 of 39 Posts
I LIKE CARS AND SH!T
blew out 2nd gear today, Out of all of the 3 mustangs i've owned this is the only trans that's gave me a problem.
What do you guys suggest i do? T45 swap? rebuild the TR3650? or buy this Tremec TR3650 Transmission for Sale
? I'm on a VERY VERY tight budget...considering i'm 17 with a part time job, still in high school and have no money saved up at the moment...
Thanks in advance.
:piss2: TR3650
Cheapest way to do if, buy a rebuild kit, drop the trans and do it yourself.
Or take your chances with a junk yard 3650 with no guarantees
The Mean Green
Check out Promotion, they offer a few options for the 3650 at fair prices.
US Air Force (retired)
To answer your question, a T-3650 is rated at a higher torque level than a T-45 and the 2002-2004 T-3650 has a higher overdrive increasing fleet mileage. 2001 was an odd year. Half got Windsor motors, half got Romeo, half got T-45s and half got the early T-3650. For changed to the later model T-3650 around October 2001 which would be the 2002 model year. Other than the overdrive gear ratio I don't know of any other differences between thee 2001 T-3650 and later models.
Ford also changed the oil recommendation mid-year from 5 quarts of 5w30 to 6 quarts of 5w20. I do not know if this change was at the same time as the motor change. I suspect it was but you never know with Ford.
Just curious, which motor do you have Windsor or Romeo?
  • Like
Reactions: GT500Chick
!FACEPLATED!
Chances are your problem its a bad blocker ring. For about 100 you can buy a new set of nicker rings and replace them your self.
Sent from my LG-AS680 using AutoGuide App
How do you tell which engine you have?
Easiest way to tell is count the number of valve cover bolts. I believe 11 is the windsor motors and 13 is the romeo.
I didn't know about the different year transmissions. I have all sorts of issues with mine that no one else seems to have which I found strange. My sticker says feb 01 so I'm guessing mine is an early model 3650 since mine came with a romeo motor. Wonder if I have the different 5th gear :dunno
To the OP, I think it's just a string of bad luck you're having with these transmissions, I've never heard of someone blowing 2nd once, nevermind 3 times in a row. It usually seems to be a grind into 3rd that's the main issue with the 3650. Listen to F8L, he knows his ****, his is faceplated lol.
Also you're 17 and you've already had 3 mustangs?
Edit to last post, just realized you said you've only owned 3, not blown 2nd 3 times, my mistake. I tried editing my post but it keeps telling me my message is too short and to make it atleast one letter long...
!FACEPLATED!
You were trying to edit in a quote that's why
It's the other way around 13 Windsor and 11 Romeo. With a build date of Feb 01 odds are you have the earlier T-3650 with .68:1 overdrive.
32v Pure Pleasure
I have the complete service manual for the TR3650 in PDF form if you would like me to send it to you PM me very useful and informative
My 2 have the 3650 and I love them both. My brothers mach1 has a rebuilt 3650 and he gets locked out of 3rd a lot.... Prob cuz it wasn't rebuilt right.
BTW have fun putting the trans back in. I did it 4 times on 3 of my buddies GT's
last year, they can be a pain to put back in. We had better luck having one of us push the engine back towards the rear of the car and loosened the motor mounts to get the input shaft lined up just right
i personaly have blown alot of trannys more than i care to admit but its how i drive them!
a couple were not my fault just high mileage my e4od went in my truck at 270,000 miles catastrophicly.
86 porsche 944 went through 4 transaxles drag racing and road racing (broken pinions) purely my fault for drag racing '
94 mustang 2nd and 3rd gear syncros on a t5 bought the car with 150,000 and 2nd was starting to go then killed it at a drag strip
04 mach 1 3rd gear is starting to go but i suspect that has more to do with being mostly road coarse mileage plus a ton of burn outs
my fathers 03 mustang convert 3650 is starting to go but he dose alot of towing of a 22ft bow rider boat
so i cant blame my trannys for the most part
Discussion Starter · #15 ·
Not sure what engine i have, according to the previous owner (some stupid kid) the motor was replaced... no paperwork or anything so i don't believe it. I'll check the valve cover bolts when i get out of school. And i replaced the clutch on my black 98, and it had LT's so dropping the trans with stock manifolds on my current 01 won't be a problem at all cause i'm in auto tech class at school, we have 6 lifts and every tool needed. And yes i've had 3 mustangs haha, NO i dont wreck them i simply just wanted something different. I'm really thinking about parking it in my garage and borrowing one of my familys gas efficient cars so i can save up faster to get the new trans... I'm leaning torwards the remanufactured 3650 off smartpartsauto, seems like a good deal considering it has a warranty.
My 3650 must be a lemon. I've had it for 2 years flat 4 shifted it for them 2 years and did a couple 5000-5500 rpm clutch drops at the track with it at 400rwtrq and 517rwtrq. I have yet to have a problem with the actual transmission. The spec clutch is another story...
Loosen the motor mounts? Ef that ****. Just take a block of wood, and put it on a jack, and slowly jack up the front of the oil pan. That'll tilt the motor bac enough to get the input shaft in pretty easily.
if you are in a automechanics class why dont you rebuild it your self and then you will have some experience with rebuilding manual trannys and ps when calling for parts make sure you tell them you are a auto mechanics student and you need parts for a project for class thats how i used to get the best deal on parts
Op i feel your pain. I hate the 3650 it is a pile of **** they dont last long and they are very clunky. I have 5k miles on my new one and it already feels like ****.
Because it is a good transmission well suited for the application--here is some tech info from a 2007 Transmission Digest article (I used to subscribe to such stuff)...
1 - 20 of 39 Posts
