So I've been doing a lot or research on both topics and still don't understand a few things. These pertain to a DD that gets whipped around corners with 3- 4 AX a year (maybe more coming this summer)
Tires:
1) Does 10-30 mm wider tires actually help out with AX?
2) In AX, is there an adverse effect to using tires that are wider than a wheels intended use? ( ex. 275 on a 8" wheel made for 245)
LCA:
1) Do spherical bushings last longer than polys (again on mostly street)?
2) Are double spherical's better for ax AND dd rather than poly/spherical combo?
3) WRT NVH, are poly/shperical = squirrel with metal boots versus double spherical = monkey with a wrench? or are people overreacting to the noise cause by either one?
I cant thank anyone who answers enough, finding these answers makes me
Tires:
LCA:
