1 - 6 of 6 Posts
Will 275 35 or 40,s fit my 2012 gt brembo car with no rubbing or any negative draw backs?Whats better 275 35 or 275 40.s?
I smell like beef
275s are 275 mm wide. The second # (35 - 40 as you listed) is the aspect ratio. IE, these tires are 35% as tall as they are wide. The higher the number, the taller the tire. If you want wider the first number needs to be bigger. Wider is not alway better. What size r the rims in question?
*edit, sorry I read you post wrong. I thought you already had 275.
Brembo rims are 9'' wide, a 275 is no problem and many guys replace the 255s with the 275s.
I,m trying to decide whether to go with a 35 or 40 sidewall.Stock size is 255x40x19 pirellis,i have seen other people going with up to 285 35,s on there stock Brembo package wheels.I know for the 285,s you have to go to a 35,but is that the case with 275,s also?
1 - 6 of 6 Posts
