1 - 16 of 16 Posts
gtscrewd
nito 315 40 18 mounted on a 18x11 wheel the tire is 28 inches tall i have the eaibach pro kit 1.5 inch drop will that tire fit or is it to tall?
gtscrewd
i just found a toyo proxy 315 35 18 that 26.6 that i think might tuck under there real nice the width im not to worried about i can ditch the shock boot im running a 26.5 mickey et street now could be a little taller but my options are limited
I have BMR lowering springs with a similar drop, and use a 28" drag radial at the track. No problems at all.
gtscrewd
Thanks guys yeah I'm down to those or the toyo proxys that are a little shorter thanks for the help the toyo has a little more street able tread
gtscrewd
Do you guys think I have enough room to fit a mh 325 40 18 in here it's 28 inches tall? This pic is a toyo proxy tq 315 35 18 that is 26.9 tall or should I just stick with this one
gtscrewd
Discussion Starter · #15 ·
Up date just pulled the trigger on a set of mh racemaster 325 40 18s will post a few pics when they get here...
1 - 16 of 16 Posts
