1 - 20 of 21 Posts
i have a 90 fox and i know i can fit a 17x9 in the rear but can i fit a 17x10.5 in the rear with out cutting out alot of stuff. if any body had done it can you sent me some pics to my e-mail thanks. [email protected]
no
Really, you cant run 17X10.5's on the back of a Fox without modifications ( besides the SN-95 5 lug conversion) ?
Because i really wanted to get some in the back, what do ya have to do to make them fit?
Fender modification, and inner wheel well modification. Quad shock delete, and proper backspacing, and you can make a 10.5 work with an 79-93 8.8" axle under a fox.
well didn't he say he didn't want to mod. anything? if that's the case you wont be able to get close to that
How are you running a 10.5" wheel, with a '95 rear end in a fox?
the 95 rear end is 3/4" wider on each side (only the axles are different), so you can fit a wheel with more backspacing on there.
In general, there is no reason to use a 10.5" wide wheel. A 9" wide wheel is plenty.
Discussion Starter #13
i want to use the 10.5 because i like the deep dish look. i have been seeing alot of them on mustangswith the stock rear.
thats a 95 not a fox
I know how its possible, i was just curious how he was doing it. It seemed like he hadnt done anything to the car to make it work.
1 - 20 of 21 Posts
