1 - 12 of 12 Posts
Win a Brand New Rupes LHR 75E Mini Deluxe Kit a Value of $450!
Rupes LHR 75E Mini Random Orbital Polisher Deluxe Kit
The Rupes LHR 75E is the polisher for difficult shapes and for spot repair operations. The LHR 75E is a must for any detailer wishing to obtain perfect results, even in the most difficult areas.
The 12 mm orbit, combined with RUPES accessories and consumables, achieves quick results on areas such as mudguards, front panels, etc.
The Rupes LHR 75E uses 3 - 4 inch buffing pads.
ERGONOMICALLY PERFECT
With its nonslip rubber inserts on the front cover, the Rupes LHR 75E is
perfect for all polishing operations in difficult to reach areas. The
operator can work in perfect comfort to produce the best possible
results.
ON-OFF SWITCH LOCK
Lined in non-slip rubber, the on/off lever of the BigFoot polisher
ensures a controlled soft start, giving the operator full control over the tool.
DESIGN
The attention to detail is not limited to just the innovative and attractive design. The modern lines and exceptional technical quality are combined with a number of details that are the result of meticulous research aimed at achieving maximum operator comfort. The non-slip rubber inserts are numerous and have many functions. In particular, the insert on the machine body is used to support the polisher when placed on a surface.
MAXIMUM FLEXIBILITY
Thanks to the backing pad with small diameter, the Rupes LHR 75E is perfect in polishing applications on small and intricate areas. The small machine dimensions and the 12 mm orbit allow a comfortable handling and accuracy in detail polishing.
ELECTRONIC SPEED CONTROL MODULE
The speed controller is both practical and easy to use. The speed of the polisher can also be easily adjusted without interrupting the work.
Kit includes:
Rupes LHR 75E 3 inch Backing Plate
Rupes Big Foot Soft Polisher Bag
Rupes Big Foot Detailing Apron
8 oz. Rupes Zephir Gloss Coarse Gel Compound
8 oz. Rupes Keramik Gloss Fine Gel Polish
2 Rupes Blue Coarse Foam Pad, 4 Inches
2 Rupes Yellow Polishing Foam Pad, 4 Inches
4 Rupes Microfiber Cloths MAXIMUM FLEXIBILITY
Winner will be drawn on Jan 31, 2013
Click here to enter to Win a Brand New Rupes LHR 75E Mini Deluxe Kit a Value of $450!
Obsessed Detailer
I entered. If i get it ill sell it to one of you guys for cheap...
Id probably keep it around, why not its free lol. Be better for wetsanding than my flex is.
That Regular Guy
Wish I could enter but I don't have a Facebook
Hot rod Stang
Entered, I rarely win any of these promotions. Happy Holidays.
Entered Lets see if i get it.
1 - 12 of 12 Posts
