1 - 11 of 11 Posts
found front and rear sway bars off a 94 mustang gt on Craigslist today, picked them up for $50 total. 30mm front 24mm rear. bought poly end links and mount bushings on the way home, didnt get charged for the bushings. install took all of 2 hours at the most and the car drives like its on rails! i'd call this a good day. :cool:
Not A Regular Member
Did you not have any sway bars before? I don't have a rear swap bar and it feels the the rear end is floating around corners when I accelerate.
Tiger's Blood!
Discussion Starter #9
I had the stock v6 setup, 25.4mm front and no rear, and yes if you push it enough it feels like the inside rear tire is up in the air. i think its worse decelerating around decreasing radius corners, reallllll sketchy.
I lucked out finding the older bars because the front is 30mm as opposed to 27mm front that came in the 99-04 gt's. I believe the rear in both is 24mm.
1 - 11 of 11 Posts
