My drivers side window on my vert will not go up the last 1/8 inch causing there to be a slight gap against the seal. It goes up all the way with the door open, but does not if it’s closed. It looks like when it starts to rub against the weather stripping towards the front that it gets enough resistance to shut off the motor (which is why it goes up completely when the door is open).
I replaced the regulator and motor about 6 months ago. Everything still feels solid and the glass is still in the tracks. I tried adjusting the bump stops but even when they are all the way up the window still won’t overcome that extra 1/8”.
Any ideas? Thanks!
Any ideas? Thanks!
