Timing dowels, transmission dowels, or cylinder head dowels?I pulled my motor apart 2 years ago with no idea what I was doing. I finally got everything I need to put it back together but I can't find those stupid dowels anywhere.....can anyone point me in the right direction to find a set?
None of the above. Windsor engines use dowels to help hold main caps instead of jack screws.Timing dowels, transmission dowels, or cylinder head dowels?
Ill look around to see if i got any laying around in a box somewhere.None of the above. Windsor engines use dowels to help hold main caps instead of jack screws.
You're the man!!!!! I'm so pissed I misplaced mine....Ill look around to see if i got any laying around in a box somewhere.None of the above. Windsor engines use dowels to help hold main caps instead of jack screws.
