1 - 11 of 11 Posts
MOAR BOOST
I should be getting my TB this week, so I have a quick question. What gaskets do I need?
I have an EGR gasket, and a TB to Spacer gasket for a GT(I'm using a GT TB). Anything else? Spacer to manifold gasket or something?
I have the little rubber gaskets in the bottom of the windstar also.
MOAR BOOST
...any idea what you would call that?
Although if you're talking about the maf to air filter adatper, I think there is some kind of rubber thing attached to mine.
1 Wheel Peel
Yea that's what I meant. I just used one off a my buddy's crown vic. You could just cut a gasket to shape if you can't find one
MOAR BOOST
Yup. I actually got a list from Steven at VAP, looks like I need an IAC gasket. And another TB and EGR gasket.
2x TB Gaskets
2x EGR Gaskets
1x IAC Gasket
you will also need 6 new windstar specific upper intake to lower intake O ring type gaskets.
V6 BIOTCH
This is what i was about to question. It does NOT take a normal upper to lower intake gasket does it. Why does this gasket not come with the kit -_-
Can anyone link it by chance ?
Also, im confused about the TB portion, it seems to be set up the same way for the gasket. ?
And tell me this you have the windstar-angled TB spacer- TB
in other words you have this: |// Tell me how you supposed to screw something together at such an angle ? |//=. the head of the screw will not sit flush ?
my kit came with brand new gaskets for everything
and the head of the screw goes in just like it would without the spacer it bolts flush to the throtle body.
I will have to take a look in the morning to see mine but i know what your talking about.
It all works fine though
MOAR BOOST
Discussion Starter #11
It all bolts together fine Mike. And if you bought a kit from VAP, you should have the o ring gaskets. Mine are green, check the stuff you got with the kit.
1 - 11 of 11 Posts
