1 - 5 of 5 Posts
How the do you remove them? I've heard yanking on them is 1 option, as well as there could be a C clip or retainer nuts, etc. Any help is needed.
Lift up the wiper arm and you will see a small lever that you pull out. Then the whole arm will lift off.
Procrastinator
They have a little clip that keeps them on. There is a little tab that will slide out a little and then the assembly pulls straight off. Hard part is putting them back on the way they came off.
^+1 pretty sure you have to lift the wiper first before the clip will pull out also.
Neither had a clip! I just didn't put enough "man" behind it while pulling up! But thanks gents!
1 - 5 of 5 Posts
