61 - 80 of 1155 Posts
Grab it by where the cam enters the phaser.
Discussion Starter #62
Discussion Starter #64
Hoosier Daddy
Do the cams you're installing require a phaser limiter kit?
Discussion Starter #69
did you get the passenger side in yet
I had to go back into town with my girlfriend lol won't be starting on it till in the morning, but I'll have all my tools so for sure getting it in tomarrow, nothing else can possible go wrong that I won't be prepared for lol
---------- Post added at 11:48 PM ---------- Previous post was at 11:47 PM ----------
Nope!
dirt/street Motorsports
If yours turns out great and you can tell a good Hp kick then maybe I'll order a set and install em my self lol
Hoosier Daddy
It depends on what cams you go with. The hotrods don't but the Mutha Thumprs do.
OK. That's what i was referring to. Wasn't sure exactly what cams the OP was installing. Mine will be the Detroit Rockers from Brenspeed.
00blkvert
You'll get a nice gain with your mods. I'm at 336/327 with a cai, cmpd, Lts, and o/r H.
I'm not sure about the rockers but I'm pretty sure Brenspeed will let you know.
Insomniac
I have a question, wouldn't it be easier to put the cam in the phaser with the cam caps off then set it in the bearings and put the cam caps on? Then you don't have to worry about spinning it with the caps on
00blkvert
What you asked is what I did. I'm not exactly sure why he can't? I slide the cam put the phaser bolt in finger tight then just worked the journals on 1 by 1 and just finger tightening them down until I couldn't then I TQed them and I was good.
Insomniac
I Figure that'd be simplest way, sorry for your struggles fullmetal, hopefully the other side goes smoother
---------- Post added at 11:34 PM ---------- Previous post was at 11:33 PM ----------
Another question, if you're not removing the followers is it necessary to set the motor to tdc? Or can you swap the cams as the motor sits
yeah, man i did two hotrod installs within a couple months, i did the second set in about 4 hours. When i installed mine i took my time and also installed my delete plugs, good luck fullmetal
