1 - 4 of 4 Posts
after reinstalling distributor car started but shut off shortly after while trying to adjust the timing. tried a few times to restart it and got nothing the battery is good and it had a new coil and wires but not getting any power to the distributor. any ideas
Discussion Starter · #2 ·
ive checked spark at the plugs as well as the coil which has power. the car motor isnt even turning over
Exhaust fume addict
Not turning over? You mean it's not even cranking? You need to go back to square one because not cranking has nothing to so with spark or the distributor. Check your battery and starter cables as well as see if the 's' terminal on the solenoid has power while the key is in the start position
1 - 4 of 4 Posts
