1 - 3 of 3 Posts
I am looking for both the upper and lower hinges for the driver side door, mine are shot and the door has about an inch of vertical play.
Since hinges would come off anyway...you could cut the current pins and replace with new pins and new bushings. From what I've seen on some around where I am at they use fox pins/bushings and cut the excess length off the pin. They also put a push nut on one of the ends
Sent from my DROID RAZR using AutoGuide.Com Free App
thanks I will definitely keep that in mind
1 - 3 of 3 Posts
