1 - 10 of 10 Posts
hi you can call me mater
So I got my engine back in the car, everything is installed
But when I tap the brake pedal the speaker(10" sub) makes a thump
Also my drivers window wont go down and if I try to press the button to make it go down it'll make the sub thump as well
What could this be?
Its never ever done this
Reps for answers here
Chill out, its the internet bro!
Where did you ground the amp to also where is your remote wire tied into
Idk I got the car with the amp and sub
This has never ever happened
I'll check right now
Needs moar meat
Most likely grounding. I get a bit of a crackle in my speakers whenever I press the gas. No idea why. I'm assuming something similar to your issue!
Mine thumps like a heart lightly when my battery goes dead. Don't know why, check remote wire? Mine is plugged into the fuse that turns on electric when the key is turned
32 blue 15 amp
I figured my out finally
Now i'm throwing codes but filly, my dad, and tuner helped me.out hopefully tomorrow I'll get everything good
What was the problem?
1 - 10 of 10 Posts
