1 - 13 of 13 Posts
well went to cecil county this friday and ran the car. my times are as follwed i will tell you it was butt cold and couldnt get a lick of traction and had to let out down the track do to some sideways driving didnt care for.
r/t .345
60 2.410
330 5.888
1/8 8.723
mph 86.35
1000 11.260
1/4 13.492
mph 95.06
like i said i couldnt ge traction at all..any idea's what i should run given the posted times. i was thinkin maybe a 12.3-12.6
You're times won't really mean anything as far as what your car can do until you get that 60' down, A LOT!
What kind of car do you have and what's done with it?
yeah i let off bad i was spinning tires at the 1/8 th so i let off around 100 and coasted threw. the track was cold it was around 35 degrees out. i have a 347 forged internals 9:1 compression ported tf tw heads holley systemax intake. mass conversion running a short belt setup. i figure the motors good for around 350-375 rwhp.
I would say its good for mid 12s if you get that 60' down what kind of tires are you running. my car dynoed ay 389hp on a mustang dyno so if you think your pushing 375hp then you should be lowlow 12s.
Discussion Starter · #11 ·
im only running bfg radial t/a..im looking into some mickey thompson et street and lake wood 50/50 rear shocks with edelbrocks drag launch suspension kit. im hoping that will allow me to hit low 12's then when i install either my bottle or a supercharger maybe some low 11's
nitto drag radials
1 - 13 of 13 Posts
