1 - 4 of 4 Posts
Carving corners
Well I just had to get my x-pipes installed through a shop, to start it was pypes o/r x-pipe. The pipes coming from the exhaust manifolds were too long and had to be cut, then there was an issue with the flange connecting with the passenger side pipe. this is when I took it to the shop they cut it and had to force fit the passenger side muffler into the x pipe, mainly because the previous owner had weld in flow masters and thy used straight pipes so its at an angle, well its installed and there are no leaks but now because the passenger side muffler pipe is at an angle its rubbing on my rear upper control arm when I go over bumps and get in and out of the car are there any cheap solutions I could attempt, aside from cutting the flows straight pipe and welding in a new curved pipe to accommodate the angle? thanks guys btw sounds sweet :D
amateur adult film star
not really anything but cutting it if you want to raise the car you could do that i hate to say it but thats about it or dent the muffler where it rubs
Cutting it is the only sure way to get rid of the rattle. You could try denting it but the chances of it working are small
1 - 4 of 4 Posts
