1 - 12 of 12 Posts
i was told the motor in my 8 8lx is from a 91...where can i find out if its true or not..i heard stamped on the block, but i cant find it..
near the oil pain rail on the driver side of the motor is a flat boss with numbers stamped on it.
the first set will be the date code
c=60's
d=70's
e=80's
f=90's
the next number is the month it was built
01=jan
02=feb
the next few numbers/letters are what type of vehicle it was in etc etc
im sorry, but i dont understand what the il pan rail is...is that just where the pan meets the block?
soo heres what i found out....i cant seem to find a date on the motor...but i went to the store to buy an oil pressure sending unit for an 88 and it matches the one on the motor....my friend says the motor was a 93...but the 93 oil pressure sending unit doesnt match the one on the motor..soooo i assume its an 88
if you lay on your back under the car, next to the area where the oil pan meets the block there will be a flat shelf with numbers and letters stamped into it. If the motor is in the car it will be on the drivers side, if the motor is out of the car and flipped up with the mains facing 12oclock it will be on the passenger side.
Look at the list of numbers, reading from the back of the motor to the front and that will be your build date
soo this is what i came up with there was a big number 32, and e7te i feel like this number is to short. is this the wrong one?!?! ugh
87 block
Discussion Starter · #12 ·
is that the right number. r u sure thats what it is. i found it on the block on the pass. side where the oil pan meets the block, but the numbers were upside down
1 - 12 of 12 Posts
