1 - 7 of 7 Posts
ok so the rear of my needs to be tightened up.
and i have been looking into a couple set ups snd need some more input
currently i have hpm mega bit jr lowers ans steeda sports springs
and tokico 5 way's
i am looking into running a phb and torque arm and eliminating the upper
control arms
my question is anybody running something similar or have any input
on how the car wil handle and how it would work in a drag set up
thanks for any help
June 2010 ROTM
I have Koni Yellow shocks, Steeda Sport Springs, MM Panhard Bar.
I plan on doing the TQ arm down the road.
It will handle very well. I road race my car. The rear is solidly planted to the ground.. like glue. Problem is the front. I get major push on the track.
Cant help you with the drag racing part, but I really like the PH bar setup.
lol my bad i never really answerd your question though.
yes it will help out your drag. ANYTHING to keep that rear from moving and twisting out of place will be bennifical. and a PHB and a tourqe arm is a great direction to go in. others might break it down more.
Abyssinian of AX
and tokico 5 way's
control arms
thanks for any help
I am not a fan of the LCA's you run due to the poly/poly bushings in them :( I recommend you upgrade to some poly/spherical ones as well as the PHB / TA set-up. You will be VERY impressed with how tame your car can be with good rear suspension. As for drag, I would not recommend the PHB / TA "specifically" for drag, but have spoken with some very well respected suspension pepes that say it can be benificial. I am not a drag guy, so I take their word for it :yes
What are you currently doing to avoid axle wrap? Are you running a single stock UCA? If so, which side did are you using?
Jazzer :)
EDIT: Forest is correct about the TA as a big benifit to drag and glad he corrected me during the time I was actually mis-speaking!
1 - 7 of 7 Posts
