That kit sounds like a dry kit for a motorcycle.Thinking about buying this for my nitrous set up, only $319 from jegs and safe on stock internals, good for 15-30 hp, think it would be a good choice paired with a tuner?
Yes...you could run it on a micro switch but you will still need heater,purge, and nitrous gague if one is not on the bottle for consistency in runs.if you wanted just to run the basics could you get by with just the $350 kit and not buy extras? plus a tune of course
Damn. I could get the full H/C/I setup from SSM, and not have to worry about blowing the engine, or refilling bottles, for that much money.Yep most people fail to mention that after the safety features your well into the 1,800$ range, unless you get some great used deals. And if you skip them, you eventually get deeper into your pocket book with buying a new motor.
15-30hp? I think thats teh wrong kitThinking about buying this for my nitrous set up, only $319 from jegs and safe on stock internals, good for 15-30 hp, think it would be a good choice paired with a tuner?
You don't need a window switch, bottle heater, or opener. But You right, its not just the cost of the kit (like i thought)Once your into everything... You'll be looking at about 1,500$
You know, digital window switch, bottle heater, bottle opener, purge.
