1 - 20 of 23 Posts
Shaun13GT/CS
Can someone give me a quick switched 12v source? I feel like wiring up my boost controller. Was supposed to do a clutch swap this weekend but had to much **** going on. So I'll have to wait.
I guess if it's at the pcm that's okay, I'd prefer the wiring to be in the car. But the one 12v switched I tapped into was the heated passenger seat. So when I put my passenger heated seat on, it shuts my shift light off lol.
Skip to about 2.15 in the video. The add-a-circuit works great, makes it super easy.
The blue wire in the overhead console is a good spot. It's also in each kick panel. It supplies power to the mirror and window motors.
Discussion starter · #4 ·
You know, where the dome lights are? There is a harness up there for the auto dimming mirror. And it is solid blue. It's where I have my radar detector connected to.
Oh good call dude, thanks I'll check that out!
Add a circuit is how I did my gauges for my '03. Worked really well and was super easy.
Just so I know for sure marc this one that plugs into the dome right?
Agreed. No cutting/splicing factory wires. and will have its own fuse
Discussion starter · #12 ·
Yup got it. Quick looped the wires around and had power. Thanks man!
Discussion starter · #14 ·
For some reason I like splicing. I'm real good at clean soldering.
Discussion starter · #16 ·
It's so purty!
Discussion starter · #18 ·
All set, I just didn't hook up the solenoid yet, no point yet lol
---------- Post added at 07:30 PM ---------- Previous post was at 07:29 PM ----------
And yeah I know I need gas. Trying to get rid of at fuel that's been in there since December
I didn't even know the gas gauge turns red lol
Why don't you put your boost controller where you can reach it better than through the steering wheel, it would suck if a Volster ran up beside you and you needed to pull some more boost and couldn't hit da switches
1 - 20 of 23 Posts
