For those of you that don't remember, I built my engine over the summer. Here are the cliffs of my setup:
The car ran pretty hard the few times I had it out, but unfortunately developed a pretty annoying oil leak that had to be dealt with. As of now, it's my belief that the rear main seal was the culprit. I will be investigating that more this week.
Anyway, the best time I got when I went to the track last was an 11.44@127.5mph. That was with a 1.8 60ft, and the car shifting at 6200rpm. I later found that I was pulling timing to 13* at launch, and my rear brakes were shot, causing me to only be able to footbrake the car to 2000rpm before it broke loose.
With all of that said, this thread will serve as a compilation of all my questions that I have along the way, along with a central location for any documentation I feel will help others. Because of this, I feel that it is appropriate to put this in the tech section.
Here are the changes I plan to be making this winter:
The end goal is a 10second car that can cut ~1.6 60s off of the footbrake.
I will update this thread as progress is made. Some goodies have already arrived so keep an eye out for updates soon!
... Also I really need the motivation so I don't try to sell the car and buy a boat, again. :shiftyeyes
- Manley 18cc pistons+decked heads yielding ~10:1 compression
- Kellogg 3.65 stroke crank
- Manley H beam rods
- ARP everything
- HPs292 blower cams
- Novi 2000 running about 15psi with the stock 3.5" pulley and a 10% OD balancer
- Circle D 4c triple disk stall
- Tuned on e85 ~18.75 peak timing
- 3.1 blower pulley+8rib conversion to see ~20psi
- Boundary Engineering oil pump gears
- Restall converter to a 5c (4000-4200 stall)
- SLP linelock to avoid cooking brakes again
- Fix rear main seal, and oil pan leak.
- Replace pan if needed
- Add MAFia if needed
