Can I get some help on where to weld my bung in for my wideband sensor? On the shorty or on the down tube? there isint much room either way...where have you guys put yours? pics?
Thanks
Thanks
I'll be at close to 450-475 post tune
that plus suspension mods![]()
:lol
ok last OT post..damn i cant run with that. what all you have done and what kinda blower you doing to get that power man. but i still say you would have a problem with 07s car on the bottle.
you got that right man. thats a sweet setup i bet it will sound damn good too. better then you can make these boys sound.ok last OT post..
it's a forged dss 306 pushing a mild 6-8 pounds of boost out of a sn2000
I'll up the pulley till I break the blower then I'll upgrade to a Novi 2000
( my car isn't a fatass! :lmao I'm just playing with ya man. )
i got cluthces......off road legs? you mean the cat delete legs? naw. the car is loud enough...and will probably get louder when I stap those headers onya fever is one word for it LOL. Im looking at clutches now!
id getwned but i would still give it a go
^ +1. Also, if you are installing a new bung you might be inclined to mount it a little low toward the bottom of the pipe, but don't do it. I know it's harder to drill the mid-upper half of the pipe but it will keep the condensation off the insulator of the o2 which can crack the insulator and ruin it. Even if you have to remove the pipe...it's better now than later. Just :2cents.The sensor should be located between 12” and 48” from the engine, upstream of any catalyst device if so equipped.
Here
