1 - 11 of 11 Posts
show95stang
what would have to be done to reach high 12's in 1/4mile..besides supercharger or turbo...starting from a stock 95 mustang gt..easyest ways would help alot thanks....
trick flow top end kit for starters... gears, slicks, and hit it with some nitrous and you'll be into the 12's
Basic bolt-on performance mods (CAI/MAF/TB/headers/midpipe/catbacks/pulleys)
Aftermarket heads/cam/intake with high-flow fuel pump/bigger injectors/tune
Stickier tires
Rear lower control arms (MM are the best IMO)
Weight reduction
apart from nitrous or forced induction, an engine swap would probably show the most improvement, IMO
engine swap? maybe to a stroked 351 lol
could stroke the 302 and do a wicked h/c/i mixed with all the right supporting mods and then some really sticky tires and learn how to drive it. alot of your time will be in your driving lol you can pull some great times if you know how to drive
nah a 408 will fit right in there!!!!!!!!!!!
if he doesnt want to get a s.c or turbo i doubt he wants spray
could be wrong but im guessing he wants to go all motor
OP...i belive you said you just got this car and your pretty lucky it already has the mods it does. h/c/i will be the biggest NA improvement (not inculding engine swap) and you already have cams and intake
id suggust looking into a port and polish job on your heads and getting some 410 gears first. then take her to the track and see how close you can get...
like hmusn said - h/c/i and some good tires
1 - 11 of 11 Posts
