381 - 399 of 399 Posts
Discussion starter · #383 ·
the time is finally here....here it is fellas. im having an issue with the wastegate though, the rubber gasket type thing inside of it got bunched when i put in the other spring so i need to replace that rubber piece. since it was doing that the boost kept building, so the hp number is under around 12psi. either way, its finally done and good to drive
cool , glad you got it going , now post up a video of a good burn out now ...
Discussion starter · #388 ·
u can see in this picture, the part that im having issues with....the orange diaphram part got bunched in one part which makes the whole thing not function like its supposed to, so i have to order one of those to fix that issue
Nice numbers bro...
Should be alot of fun...
Discussion starter · #393 ·
got a lil night vid...kinda hard to see, 65mph is directly above the v6 logo tho to get you an idea of speed.
[ame=http://s41.photobucket.com/albums/e257/wljohnson05/?action=view&current=1128082209.flv]
[/ame]
Discussion starter · #395 ·
ok lets see daytime vid with dead stop take off , and or some track times man LOL
haha that was just a spur of the moment thing tonight on the way home. usually its not warmed up so i dont do those from stop things when i leave from places. that was from about a 5-10mph roll. there wont be any track times for a good while bc i still have to replace that piece in the wastegate before i make any track runs.
