Anyone know what can cause this? I have 4:10's but there is no way that should cause it to be 20 mph off!
speed cal wont work on a 97 not an electrical speed sensor they started those in 98 he needs the gearget that speeda cal
:lmao:withhomo:funnah
/fail
Are you sure ? From Speedometer Recalibration Gears - '79-'98 Ford Mustangin the 96-98 cobras they had the same tranny as the GT
I guess by this info ... I would need the "8 tooth" for my GT ?Instructions: Note transmission type, model and resulting drive gear. Cross reference with your rear-end gear ratio to find the correct "recalibration" gear for your application.
Manual Transmissions with 7 Tooth Drive Gear
1983-1989 T-5 OEM
Pre 1993 T-5 Aftermarket
1996-1998 Cobra T-45 OEM
All Tremec Transmissions
Manual Transmissions with 8 Tooth Drive Gear
1990-1995 T-5 OEM
1996-1998 T-45 OEM Except Cobra
From Latemodel Restoration Supply - Mustang Parts, Chevy Truck Parts & Dodge Challenger Parts... 94-98 SPEED SENSOR MUSTANGspeed cal wont work on a 97 not an electrical speed sensor they started those in 98 he needs the gear
I know we think AM is wrong but does anyone know for sure ?This works on Mustangs with both Computer Controlled Electronic Gauges and Non-Computer Controlled Electronic Gauges (1994-2004 Mustangs).
this thread is full of mis information... 96-98 use a gear driven VSS. and you can just change the gear if you want to be inaccurate....I'm almost positive the only thing you can do is install the physical gear and you can't use the electronic.
fix't and repp'edI'm almost positive that you should read MustangMatts96GT's post above this :yes.
I'm glad you posted this. I was reading through the whole thread waiting for someone to correct it. The Speedcal definitely works. Mine did until it shorted out or something. I haven't figured that out yet...but I will.this thread is full of mis information... 96-98 use a gear driven VSS. and you can just change the gear if you want to be inaccurate....
or you can buy a speed cal... it requires some wiring (5 minutes worth) and plugs in. i have it in my 96 and it works well...
SO yes you can use Electronic Speed Cal to change the speedometer... the speed cal changes the resistance being sent frm the VSS to the speedometer to correct it....
99+ you can use a hand held, but not for 96-98s
the gear will work, but it will be off 1-3mphSo... the gear won't work? It will save me alot of money if it does, but if not i'll order the electronic one from AmericanMuscle.
