1 - 20 of 26 Posts
tarpeeler
i have a 08 gt and for some reason now the passenger side sits a little lower than the drivers any experience or suggestions?
tarp go park the car on a flat surface, bring your camera, remove the fat chick, and take pictures and show us.
The car, not the chick.
Unless you're into that.
which you are zippee do da
hey i tried to give a real answer, but NOOOOOOO you all just wouldn't give up on the lardo's.
hey tarp, if by chance you have already changed out your suspension then it should also be under manufacturer warranty. you of course will have to do the work to remove and reinstall your factory components until you can get replacements though.
Its most likely tire pressure. Make sure all your psi match and drive to a level parking lot. Step back a few feet and see if it is still sinking. Use something to judge like a tire iron. If it still is sagging it could be a couple things. Best bet with it being an 08, take it to the dealer and have them fix it. Use warranty while you got it.
1 - 20 of 26 Posts
