i know i know... going carbed need help
ok like many others i have decided to go carbed. main reason is the person that owned the car before me did a real hack job on the wiring harness of the car and now i have little problem that need to be fixed or removed. so i did a search and think i have everything i need for the swap could someone put some input in to as if i need something else OR an solution to my messed up car???
!. intake and Carb
2.85 dizzy
3. i plan on going the cheap rout and taking out the stock fuel pump and putting a piece of hose in the tank, or a sump havent decided
4. holley blue fuel pump
5.return style regulator
that should be about it right?
any input would be greatly appreaciated.
!. intake and Carb
2.85 dizzy
