i wana know some other site other then racer walsh ,Esslinger Racing ,and forced 4 and resto 50 so if u would list some more
Assuming you just wanted to hit the low end of that scale, and you're talking crank hp, not at the tires, you're talking 130hp/L. To give you some comparison, the most efficient 4-stroke piston engine I know of in an automobile is the 2.0L F20C in the S2000, which puts out 120hp/L, but uses DOHC, VTEC, and 9,000 rpm to do it.yea im wishing for about 300 to 400 hp
Yeah, I'm aware of the 2.0 vs 2.2L. They both put out 240hp at the crank. I was using the earlier, lower displacment motor as the example as I was attempting to make the problem as "easy" as possible to show how difficult and expensive it still was.the f20 c is a very good engine but your figures are very low the f20c is the pre 2004 motor and it put 203hp to the wheels at 8500rpm the newer one which is a 2.2 has 210hp @8000 at the wheels.
Honestly, you're better off saving your money, and buying stuff all at once. Everything needs to work together, and buying things onesey-twosey leaves too much time for you to change your mind.yea i was going to end up buying one thing at a time then doing one big ass project like do some small **** then when i get another day driver its all going on there
Best seat-of-the-pants upgrade will be gears. Considering the low-rpm nature of that motor, I'd go 3.73s. Will be a HUGE upgrade from the stock 2.73s.yea thats what i ment to say lol
but right now i want it to get some balls and haul lol
