I would also like to know more about the window fix. I have had trouble with my 97 GT windows coming out of the track since I bought it 10 years ago. The ball jumps out of the plastic ring leaving the ring in the track. Always when the window is up because the ring is in the top of the track. I have put it back at least a dozen times on the driver's door and now the passenger's side is doing the same thing. I never tried glue because it appears the ring has to rotate on the mounting so it will slide up and down in the track. What kind of adhesive could I use? And how should it be applied.
