Hello everyone i got a big or small problem wihth my 00 gt.
at 2k i get this tapping noise at the back of my motor. it only does this when the engine is warm and only tapps in the 2k rpm range. not at idol or at 3k and above.
i have checked the timing chain, its brand new and tight.
i checked the lifters, replaced all 16 and still the tapping.
i pulled the fuel injector plug on the n0.8 plug and the tapping stoped. i reconnected the fuel and pulled the spark and it stoped on 8 only!
i have heard rod knocks and crank knocks but this seams to be not the issue, although the chiltons manual says that pulling the spark tells if the rod is bad. i have put 10k on this motor thrashing it into submission, and a rod would have long come thru the block with what i put it thru. i even sprayed 250 shot of juice on her and its still holding up. just tapping only in the 2-2500 range.
what else could make the no8 cylinder tap like a sewing machine? its more of a ticking than a knock, like valvetrain noise.
i cant keep pulling up to chevys with this god awful tapping. any advice?
