intake and tb issue
1.5K views 11 replies 8 participants last post by  Eagle2000GT
#1 ·
I installed my american muscle cai and accufab plenum and roush tb today. Everythings ok no cel's or nothing but my tb sticks here n their when I get on the gas pedal, I was told some 75mmtb's have a vaccumm seal lock issue because their is no hole in them for pressure to release like the stock one? how can I fix this issue? Also my cai is making a whistling/turbo sound like their is a leak or something I checked every hose and clamp its all on tight is that normal to sound like that?
#10 ·
mine cai whistle too at about half throttle, and my 75mm tb stuck too at first so i just made a couple of adjustment's on the throttle and it seem's to be working great now.
#12 ·
If it stick when you first press the throttle at idle with the motor on, and it doesn't with the motor off, then it's a vacuum lock. Like Bottled said, turn the stop screw about a 1/16th to let a little air past the butterfly valve.
