So ever since the T5 swap, my idle has been crap. The engine wanted to stall or tried to at every stop light despite me swapping out IACs and resetting the idle speed to about 750 or so.
So I finally installed a junkyard set of these 19lb injectors with the four squirter holes. The resistance of each injector checked in at between 14.8 and 15.1 ohms so I know they were electrically good. I wiped them all clean with just a rag and made sure there was no debris blocking each of the four squirter holes, lubed their original o-rings with oil and stuck 'em in the fuel rail. I also installed new intake gaskets with the exception of the lower intake to head mating gasket. I was considering having the injectors professionally cleaned and rebuilt with new filters, pintle caps and o-rings but decided to keep my $90+ to myself lol......
The engine fired up first try and holy crap is it smooth. This thing idles as smoothly as my '96 Cobra 4-valve engine did when I first bought the car (used). Barely any relearn time for the computer to remap the short and long term fuel trims but I did have to adjust my shift points or else the car would bog just a bit at the acceleration of the next gear.
I'll report back later with any increases or decreases in fuel economy.
